Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
Wheeler chair robot
Wheeler Chair Robot
I saw that last year somebody had built a wheel chair robot?. My idea for the new Robot will be as a stage mascot that can also pretend to play the drums on stage. My brother has a live Metal band every Saturday night and most of the time we have trouble with no drummer showing up. We end up using a Drum machine instead with the 2 other guys on real guitars and singing. So Terminator will be able to move around and substitute behind the drum kit with the Live drum machine signal activating terminator arms at the drums. Also need him to move around in a wheel chair , so is anyone out there that has done this wheel chair hack, looking for suggestions on power/motor controller connections etc...should not be too hard just larger than I'm used to building. This is a youtuber that bought what I just bought,takes a month to get from China and we are building the rest of the Endoskeleton to integrate in wheel chair....
#25
:)So Now the Testing is done to control my old Chimp Alive Neck servos(Older DC motors with mechanical increments)Used the old Rad robot as test subject. The up and down motions can work in a script using the PWM single channel plugins can also control T 800 eyes using that method but the left and right motions work directly from the Camera plugin when I enable the movement tracking option and there are many fine options that you can adjust to get the right type of tracking speeds and smoothness movements...Me Likey! The color tracking also works but not as good as the motion tracking...somebody will enter the room and robot instantly turns to follow the person's movements, it is incredible to watch! Next is to add this servo to the Terminator head/base with special shock absorber connectors as it weighs about 5 pounds and the servos will need help supporting it and the sudden movements up down left and right.
#26
Cylon Kit So now I have a second robot on the way ,got the kit to build the original Cylon Helmet ,not sure if he is sending me the rough chrome kit or the un-finished vinyl kit either way it should be fun to put together and stick an EZ-B in there! Now T-800 has a friend on the way! If you need any other props like a Predator or anything he builds all types of Starwars,Horror anything Sci-Fi these for TV and movies....https://www.facebook.com/Kropserkel/photos/a.389055574322/10156883260729323/?type=3&theater
#27
The Terminator inner core body is just a long PVS pipe that goes from the bottom to the neck and using the old Rad body to house the EZB,H bridge and head movement/waist motors. The bottom is the Chrome shell from a Vacuum all hollow now that will house a large 12 volt Marine battery or 2 lighter 12 volt batteries,need to see how much weight the motors will handle when they come in tomorrow.Will mount them on the sides of Vacuum shell. I do want the bottom heavy so it will have better balance when running outside. Also Future designs ,going to add large Actuator pistons to raise the arms/neck head another 2 feet taller as it is now at 4 feet but a Terminator should go at least 6 foot tall! When travelling it will stay short but standing it will raise it's height.Shoulders and arms will be coming too but later.The old rad body will be completely made over and chromed. It is still just in the rough testing phase but I hope to let it run down the street if all this snow melts tomorrow from the rain! I have decided to just make this robot frame universal for the other Cylon helmet I ordered instead of having 2 robots,use the same frame for both as the chromed Cylon helmet will fit over the Terminator's Skull...interchangable ....robots in disguise...Transformer,LOL! I am going for the modern Exoskeleton T-800/Cylon Hybrid frame design. https://darthmojo.files.wordpress.com/2008/05/cylon01-cu.jpg
#28
;)Now if you can just think of problems outside the box there are always simple sollutions. Instead of expensive Actuator Servos I have an idea from being a car guy...The old scissor jack that you can lift a car really high could be used with this method to make Terminator skeleton double it's height. Only need a heavy duty motor to turn a modified scissor jack up or down or whatever design is used in a power window even! A scissor jack could be used if it is made with less resistance to turn, I have 3 of them in my car but a motor would need too much torque right now but could possibly made to work with another window Lift motor.
#30   — Edited
I am not really liking the old rad body in the middle, I think I will go out to home hardware and see about getting a thick plumbing pipe or an aluminum tube to be strong enough to go from the bottom all the way up to the neck part, The rad body just looks to old and "Plastic" A bit too flimsy for a Terminator,LOL! The PVC pipe I have now is also not strong enough in the center ,it will be okay going to the skull part only. It needs to be made really tough and sturdy. I also want to make the pipe look like the spine from the Terminator movies so I will need to get creative and shape out some hexagon spine connectors to go all the way up and have them looking like chrome after.Many nuts and bolts I will need to buy.More smaller tubes as well to imitate what is in the movie then the chest and back plate I will use some type of light weight plastic and chrome paint them.
EDIT....... On more testing ,the Rad body in the middle really seems to help as a shock absorber when moving forward or backwards, The body has a motor and a spring that controls the waist movement for lean forwards/Lean backwards and this gives the whole robot a nice cushion effect as the head is heavy at 5 pounds and will slightly move backwards if it is taking off suddenly and slightly forward when stopping suddenly, a shock absorbing effect, Possibly good to have. It will be hidden anyway with the front chest plate bars and arm /shoulder linkages. I will likely paint that inner body black but have all the tubes and chest in chrome as well. Trying to replicate what side show does on their whole 1000.00 bust piece.....https://www.youtube.com/watch?v=YAj3D6O-yjA
Edit------So I have been just studying all the sideshow models of the T-800/600 life size statues and I can see what I am doing wrong with my Model. It is directly where the bottom of his neck is, that is where the Shock absorber shoulders and arms are supposed to go and on my model the Rad body arms connections are way too Low. I am going to need to raise the body up to the neck bone part and from there buy the 4 small shock absorbers (or just make look a like shocks) The chest plate is easy to make and just add on to the Rad body with self tap screws(Or hot glue LOL!)Similar the back plating. Some of my creative artistic painting skills to get the battle damaged chrome look and I just love it when a plan comes together! I will grab my scissor jack and add that to the bottom inside the vacuum battery can. I found out any old cordless drill can crank the scissor jack up and down. So did I mention I want this T-800 thing to look like a real monster at these out door festivals in summer, Take it out for a night walk and just watch the old people collapse from heart attacks LOL! I am worried about getting the mouth jaw part to move as it talks since, the Chrome process has glued it all shut I have not tried to pry it open yet,a bit too scared to crack any other chrome around it.
#31   — Edited
Well since the new car window lift---robot high torque motors came in yesterday I spent the last 3 hours doing surgery with some of the hardware clamps and install the new motors to modify the Terminator Base mobility drive.These motors are way more heavy than the puny 6 volt original Rad drive motors! I will try a quick test using the old H-bridge at half power and see what kind of movement I get as these are 15 Amp 12 volt motors.Could be overkill for the old plastic Tank and rip it in half! Too bad there is no more snow outside,would be fun to see this thing rip around on the snow fields! Likely gonna need to upgrade plastic base tank to Aluminum heavy duty frame.
Edit---Testing the 2 motors on a bench with my 5 Amp 7.4 Lipo battery went really well! even with half speed the motors are very powerful and not too fast just perfect for a robot . They have internal worm gears which means they will not move not even budge until power is applied and then the torque is so high you can't stop them with your hand. Very quiet too, I am so impressed,exactly what I wanted!
#32   — Edited
Here is a cool idea for a stage performing Robot!
I attached the front chest piece higher up and now it looks proper where the shoulders and arms can fit but I will need to cut the bottom a bit to make it look right and connect to a back plate with custom made shock absorbers as rod links. It is starting to come together the way I planned it in my head and I can make it rigid as tall as me!
