Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
Vertical Servo Question
Hi, i'm have a bit of problem with the vertical motion of my servo.i am using an DAGU Pan and Tilt Kit with mini Servos, i have the horizontal working fine and have it tracking me around the room with the camera and everything works apart from when i try and get it to track something vertical. it kind of nodes up and down like it's fighting it's self then just goes all the way up or all the way down and stays there till i move it using one of the other controls. i've tried adjusting the servo speed, the red lines, inverting the controls, plugging it into a different port and even new batteries but with no luck. the servo (Pan and Tilt Kit) works perfectly with all the other control's but not with the face, colour and motion tracking.
please can someone help?
Simon
Check the settings in the camera config. Make sure your min position isn't greater than max position and make sure it is set right for inverted or not.
Every control has a question mark next to the close X button. Pressing the question mark button will direct you to a tutorial page for the respective control.
Yep I've done all that. I've even had it so it can only go vertically and the same happens. I would say it was the servo but it works fine with all the manual controls. Could it be a software problem? I'm running the latest version on windows 7. I've reached a dead end :-(
Can you upload your project? (Use the attach file to the left)
Okay cool :) if you can look at it that would be great.day1.EZB
I'll take a look and check it later when I can get my bot down to hook up to ARC.
I hada quick look, X axis is set to N/A, what is this usually set at? And what is Y axis on too (project indicates D0). Just want to make sure you hadn't accidently set both to the same port or something like that.
Initially it looks like it should work though but will check properly when I get home later.
Yep that's right I put the x axis on n/a just so I can see if I can get the y axis working. But even with just the y axis it still just nods up and down then goes all the way up or down and stays there. It does see my face, red ball ect but it just can't lock on and nods away. But thanks for looking at it for me hopefully you might see if or what I'm doing wrong.
I forgot to mention the x axis is D1.
Config wise it looks the same as my pan/tilt which works fine.
I'm unable to check it on my EZB as it looks like I forgot to switch off my robot when I moved it out of the way and drained my LiPo. When I get a chance I'll try it if nobody else steps forward to test your project or spots something I haven't seen.
