Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Using 2.4Ghz Camera's Communication Module On The Ez-B
Hey, I've noticed the bluetooth communication in the EZ-B has a certain low range, it stops working at about 5 meters, but the camera has a very large range. I'm wondering, is it possible to use the camera's communication module to communicate with the EZ-B? I understand I'd have to do some programming to get the data off the USB, but in the hardware aspect, is it possible?
No. They are not the same protocol
The ez-b distance depends on your computers antenna. If you desire further range, consider replacing the Bluetooth with xbee or synapse:)
