May we please have some instruction or video on the Use of the Script Console ?
Please see my attached file, Latching Print Loop, 28-Jan-2013.EZB .
Thank You,
[email protected], 602-246-1246(H)LatchingPrintLoop,28-Jan-2013.EZB
EZB Connection
— Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C.
Thank You,
Can you be more specific?
The Script Console is a realtime script "command line" of sorts, so if you were to type Print("Hello World") it would output Hello World in the script console. The script console is the same as EZ-Script but instantly runs the command when typed.
What is it you are trying to achieve using the script console?
