Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
#17
@thetechguru
Wow! Thank you so much. This is exactly what I needed.
So if I have already have an FTDI cable and jumper wire with the camera cable, I am good to go correct?
#20
I just hooked up this one https://www.robotshop.com/en/ftdi-basic-breakout-3-3v-6-pin-header.html to my EZ-B and it worked perfectly at 921600 from 2 different computers. Unfortunately, I also discovered that the battery in my Acer W3-810 tablet is shot. It works plugged in, but is sitting at 12% charge and won't take a charge, so now I need to find another computer to use as the embedded device in my robot:( I have a VOYO V2 that can run headless,, but it sometimes overheats, so I would be afraid to use it in a robot, and I liked the idea of having a touchscreen on the robot so I didn't always need to have another computer running to work with it. Off to gearbest and eBay to see what is available these days...
Hi Alan,
Is the Latte Panda on your list? I wanted to get an opion if this was a good computer to consider.
Ron
#22
If I decide to go headless it looks like a good affordable choice. I found I can get a replacement battery for the W3, but it is a little tricky to replace and costs quite a bit, so more research needed.
I thought I found a good cheap tablet at Gearbest, but you can't use the USB port while it is charging, so that isn't good for a robot I want to run for hours.
#23
i like the latte panda - put TightVNC on it or use RDP and you won't need a screen. There's plenty of iOS VNC clients as well. I prefer RDP because it is faster.
Although, nothing beats actually seeing the screen on your robot:D
#24
Yeah, there are some design reasons I wanted a screen. I have a couple of olf Xenarc 7".screens I could use for a local display but they are only 800x600 resolution and not touch screen, so won't be good for EZ-B, but maybe OK for some of the other purposes.
Decisions, decisions....
