Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Updated Microsoft Cognitive Emotion & Bing Speech Recognition?
I noticed that EZ Robot has published an update to each of the Microsoft Cognitive Emotion & Bing Speech Recognition plugin's. What was done and is it worth me updating my version? If it's worth it, how would I go about updating the version I'm currently using?
Also this is probably a Bing issue (or even something within my home network?) but I've noticed a lag in my Bing Speech Recognition. ARC seems to respond as fast as usual because I can see the control process the phrase I say. Then there is a pause sometimes of up to several seconds before I will receive a response from Bing. Then the ARC will complete it's script. This process used to be almost immediate. Any thoughts on how I can get this to speed back up? I'm not using Pandorbots but just having the Bing response trigger scripts I have. Pandorbots is not even in the mix here.
updated to the latest microsoft libraries. and a fix for why sometimes the vision cognitive plugins would show a big X in the image
Thanks!
I've never updated a plugin. Do I just redownload it and reinstall?
If you already have the plugin then when a new version comes out ARC asks you automatically if you want to upgrade the plugin when you open ARC to a blank project
