Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
There are several UART command when you open/edit Script . Just do UART search under Script Help
there is also UART example available in ARC(EZ-Script Function Syntax)
You may also refer to a recent post https://synthiam.com/Community/Questions/6241
There are only three UART designations 0, 1, & 2. The firmware determines which digital port is used during a receive or transmit command.
That would be 3 UART ports... No need to designate RX and Tx ports...
Sample code on how to use them is below (using a Roomba)... using uart port 3
uartinit(0, 2, 57600) #initiate the port
sleep(20)
repeatUntil(1=2)
 uartWrite(0,2,142,7) #Check Roomba Create Bump and wheel drop sensor
sleep(20)
  IF (UARTAvailable(0,2)>0)
    $x=UARTRead(0,2,1)
    $x=GetByte($x)
print($x)
endif
sleep(50)
endrepeatUntil
