Output Audio From EZ-B icon Output Audio From EZ-B — Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples. Try it →
France
Third Party Robots - Bebop Drone
Hi, I'm looking for a way to do what you did with the AR Parrot Drone here : synthiam.com/Tutorials/Help.aspx?id=160 but with the new drone from Parrot : www.parrot.com/fr/produits/bebop-drone/
Are you working on that subject ? Can I develop my own Third Party Control for the Bebop Drone ? If so, is it possible to get the code of the "AR Parrot Drone Movement" ? Maybe, there are just some adjustments to do, although the Bebop Drone runs with the new ARDroneSDK3 which isn't compatible with the previous generations of Parrot Drones.
Thanks for your time
Yeah.. my bad for the French version;)
No problem. This is an international community.:)
If you use the SDK, I think you could. You just have to code it yourself. I like Parrots products, but 10minutes flight time isn't enough for me.
