Hi, The image of my camera freeze when the wheels of my robot (Wall E) work. Why? Help! Thanks!
Excuse I, my English is very bad.
Speech Script
— Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs.
Is your camera powered or connected to your ez-b for power? What kind of wheel motors are you using? Are you using the latest version of ARC? . Please provide more information for someone to help you.
Is there much radio interference from the camera? It could be related to that. Otherwise maybe it's a strange issue I've never experienced before. Try today's release, as it does pertain to the video processor.
I would try alternate power source other than the ezb for the camera. Direct to battery through a regulator. 5v regulator. if im right its the ground on the ezb feeding back to the camera.
I will do some tests tonight or this weekend. thank you
Hi, I found the solution.
I had taken the solution of TLouis with added 3 diodes for powering directly off EZ-B and it had to cause radio interference, i think. I deleted diodes and it works perfectly (methode of winstn60).
Thank Scuse for my english (thank Reverso.net) IoI
