Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Netherlands
The Ez-case
A few weeks back, while writing a report, I had it. The stroke of brilliance. I've always looked at my EZ-b as a fragile, I find that all electronic boards look fragile when they don't have a case or a housing that protects them. Eventhough they usually aren't, but I do.. So here comes the idea, a case for the EZ-b. A few hours of "Inventoring" and mesuring later:
I added all the holes you would need to plug in servo's and other things, but I also added a hole on top, so that you can add a fan to cool the heatsinks. Also I added a hole in the middle of the case. If I wanted to use an external communication system, like USB, Synapse, Xbee, WiFi, etc. And finally I added holes to the bottom of the case for easy mounting.
Last week I ordered it from ShapeWays, to have it 3D-printed and today it came in. Here and there some adjustments (it's always difficult to design something for an object if you don't have all dimensions or a CAD model of the object), threaded the holes made some spacers and taadaa:
Presenting the EZ-Case
It works, looks great and is easy to assemble.
If anyone else likes it, wants one, you might be able to motivate(yell at me, "I want one!") me to design v2.0 that requires less "adjustments" ,is a little bit smaller and a few other things that I would change now I have my one.
Netherlands
Twitter YouTube
That's an awesome enclosure dude:D
Nice! I'd do what DJ suggested and post it to thingiverse. I'm sure a lot of people would love to have the files for your enclosure:)
You need something for doing this, great job. Thanks for sharing. John
I'll add my voice to the "Yes we want it" crowd. And also my compliments on the great work.
One comment. I would leave the fan outside the case. That way if someone needs to save space but doesn't need the fan, they can just remove it. With it inside, that height will be used whether you install a fan or not. This design also makes the fan easier to replace.
Netherlands
Thanks guys for the complements, I'll eddit the current design, make a few changes here and there and I'll make a tutorial on how to make it like mine. Before that, I'll post the new design.
Netherlands
#15
So V2.0...
Starting at the top left, I increased the thickness of the bottomplate, this gave (top right) the possibility to countersink the screws on the bottom. In the previous version you would need to add your own threads. Now on the bottom left, I increased the total hight of the top half of the case. By doing this I'm securing the fact that you can still use it with a bluetooth module or it would be a narrow fit. Continueing with the bottom right picture, I moved the square hole for the power supply 2mm to the left and I made a round cut-out in wall above where the connector of the bluetooth module would be. This cut-out would allow thicker cables going out of the case.
The EZ-Case V2.0
Files EZ-CaseV2.0.zip
Let me know what you guys think.
#16
Wow! Keeps getting better. Totally dig it. We will print some!
