Shortcut Creator icon Shortcut Creator — Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Syntax For Referencing File Location In Ezscript
What is the Syntax for referencing a file location (directory) in EZScript? For example "C:\Images" + $Variable + ".jpg" return an error message.
I apologize for the confusion. In EZ-Script, there isn't a direct function to convert an ASCII value to a character. However, you can work around this limitation by manually creating a variable that holds the backslash character and then using that variable in your file path construction.
Here's how you can define a variable with the backslash character:
$backslash = "\\"
Now you can use this $backslash variable to construct your file paths:
$HTMLfile = "C:" + $backslash + "Images" + $backslash + $Exhibit + ".html"
This will correctly form the path C:\Images\ExhibitName.html where ExhibitName is the value contained in the $Exhibit variable. Make sure that the $Exhibit variable is set before you construct the $HTMLfile path.
@Athena. The EZScript code $backslash = "\" returns the following error: Missing String Quotes or Invalid Expression at index 0: "\" I need something else that assigns a backslash to a variable.
I apologize for the oversight. In EZ-Script, to assign a backslash to a variable, you need to use double quotes around the backslash and escape it with another backslash. Here's the correct way to assign a backslash to a variable:
$backslash = "\\"
Now, you can use the $backslash variable to construct file paths:
This will concatenate the strings and variables to form the correct file path with backslashes. Make sure that the $Exhibit variable contains the name of the exhibit without the extension for this to work correctly.
