On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
Syntax For Referencing File Location In Ezscript
What is the Syntax for referencing a file location (directory) in EZScript? For example "C:\Images" + $Variable + ".jpg" return an error message.
In EZ-Script, when you want to reference a file location that includes a variable, you need to concatenate the strings properly. To do this, you use the + operator to combine the different parts of the file path, including the variable and the file extension. However, you also need to ensure that the backslashes in the file path are properly escaped because a single backslash is used as an escape character in strings.
Here's the correct syntax for referencing a file location with a variable in EZ-Script:
"C:\\Images\\" + $Variable + ".jpg"
Notice that each backslash is doubled up (\\) to escape it. This tells EZ-Script to treat the backslash as a literal character in the string rather than an escape character.
If $Variable contains the name of the image file without the extension, the above line will correctly form the full path to the image file. For example, if $Variable is "image1", the resulting path would be "C:\\Images\\image1.jpg".
If you encounter an error, make sure that the variable $Variable is defined and contains the expected value before this line of code is executed.
@Athena My code is... $HTMLfile = "c:\Images\" + $Exhibit + ".html" and it returns the following error: Missing String Quotes or Invalid Expression at index 18: angry arms
In EZ-Script, when you are concatenating strings and variables, you need to ensure that the strings are enclosed in quotes and the plus signs (+) are used outside the quotes to concatenate the parts of the file path. Additionally, the variable should not be enclosed in quotes as it is not a string literal but a variable that holds a string value.
Here's the corrected syntax for your code:
$HTMLfile = "c:\\Images\\" + $Exhibit + ".html"
In this corrected line, the parts of the file path that are string literals are enclosed in quotes, and the variable $Exhibit is concatenated without quotes. This should resolve the error you are encountering.
Make sure that the variable $Exhibit is assigned a value before this line is executed. For example, $Exhibit should contain the name of the exhibit, such as "angry_arms" (without the extension), and the resulting $HTMLfile would be c:\Images\angry_arms.html.
@Athena. OK. That didn't work as the code you quoted is the same as the code I gave you. Here is another question. How do I convert an ASCII value to a character in EZScript? For example ASCII(92) to a backslash character.
In EZ-Script, to convert an ASCII value to its corresponding character, you can use the Chr() function. The Chr() function takes an ASCII value as an argument and returns the character that corresponds to that ASCII code.
Here's how you can use the Chr() function to convert the ASCII value 92 to a backslash character:
$backslashChar = Chr(92)
After executing this line of code, the variable $backslashChar will contain the backslash character (\). You can then use this variable to construct file paths or for other purposes where a backslash is needed.
For example, if you want to construct a file path using the backslash character, you could do something like this:
$directory = "C:" + $backslashChar + "Images" + $backslashChar
$filename = $directory + $Exhibit + ".html"
This will create a file path string with the correct backslashes included.
@Athena. Sorry but the Chr() function does not exist in EZScript. IS there any other solution?
Apologies for the confusion. In EZ-Script, to convert an ASCII value to a character, you can use the GetChar() function. The GetChar() function takes an ASCII value as an argument and returns the character that corresponds to that ASCII code.
Here's how you can use the GetChar() function to convert the ASCII value 92 to a backslash character:
$backslashChar = GetChar(92)
This will create a file path string with the correct backslashes included. Make sure to enclose the other string literals in quotes as shown above.
@Athena. Sorry but the GetChar() function does not exist in EZScript. Is there any other solution?
