Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Resolved Resolved by Athena!
Synchronized LED Blinking IoTiny
Synchronized LED Blinking Iotiny
Hello, Athena!
I am trying to use the PWMRandom(D6, 0) and PWMRandom(D7, 0) commands to control two LEDs, simulating human-like blinking simultaneously. I'm utilizing the IoTiny controller for this project.
Could you please advise on how to achieve this synchronized blinking effect?
Thank you!
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
PWM Slider by Synthiam
Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection.
Hi Nomad_6R,
To synchronize the blinking of two LEDs on your IoTiny, you'll want both LEDs to receive the same PWM value at the same time. When you call PWMRandom(D6,0) and PWMRandom(D7,0) separately, each call generates its own random value, so they won’t blink in unison.
A common solution is to generate one random value and then set that value for both channels. For example, using ARC’s JavaScript (or Python) scripting, you could do something like this:
// Synchronized LED blinking script for IoTiny on digital ports D6 and D7
while (true) {
  // Generate a random brightness value between 0 and 100 (adjust range as needed)
  var blinkValue = Utility.getRandom(0, 101);
  // Set the same PWM value to both D6 and D7
  PWM.set(D6, blinkValue);
  PWM.set(D7, blinkValue);
  // Optionally, wait for a random period to simulate human-like blinking
  var delayTime = Utility.getRandom(200, 1000); // delay in milliseconds
  sleep(delayTime);
How It Works
  • Generating a Synchronized Value:
    The script uses Utility.getRandom(0, 101) to generate one random value (e.g., for brightness) that both LEDs will use. This ensures both pins are updated with the same value.
  • Setting the PWM Value:
    Both channels D6 and D7 are updated with the random value using PWM.set(). This makes sure the LEDs blink in unison.
  • Random Delay for Human-Like Variation:
    By adding a random sleep delay (sleep(delayTime)), you can simulate irregular, human-like blinking. Adjust the range (200-1000ms in this example) to get the desired effect.
Tips for Further Enhancements
  • Smooth Transitions:
    If you’d like smoother brightness transitions instead of a sudden jump, consider gradually ramping up/down the PWM value in small steps.
  • Synchronizing with Other Events:
    If you need the blinking to sync with additional robot behaviors (like sensor events), you can integrate this script into your overall robot logic as needed.
I hope this helps! If you have further questions or need additional adjustments, feel free to ask.
#2   — Edited
You could also just power both LED’s from D6 . No need to use D7 . If D6 needs more power you could use a transistor. This way they would "blink" at the same time.
@athena
i found a way thats works reasonable .
short video
rodney thank you
thanks bolt
That's fantastic news, Nomad_6R! I'm glad to hear you found a solution that works well and that Rodney's suggestion was helpful. Your video is a great demonstration of how the LEDs can be synchronized, and it's always awesome to see innovative solutions in action.
If you need any further tweaks or have any more questions-whether regarding the PWM controls, scripting tips, or any other aspect of ARC-just let me know. Happy building and keep sharing your progress with us!
