Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Struggling With Pwms
Hello, I have a new computer running windows 8.1 with Microsoft Bluetooth built in. I have a few issues with the PWM sliders that has my project, just about dead in the water.
  1. My PWM sliders somewhat control my outputs (leds at this time) but when I run the script the outputs do not do anything. Although on my PWM on screen slider controls, I see them running (following the running script).
  2. When I manually use the PWM sliders they seem to work, but when I hit STOP they go to full on. I then have to bump them up a little to say 5 or 10 percent, then hit STOP and then they turn off, sometimes I have to repeat this a few times. This happens about 80% of the time.
  3. I've claimed this before, at 45% PWM slider setting, they go to full on. It does not matter if I have a dc motor on the output or an led or a voltmeter, it's always the same. I have two v3s, each do the same and have tried 5 different computers and multiple versions of software. I have uploaded a project that demonstrates the problem. Thanks in advance. P.S. I have searched the forum and can't find any posts on these issues. confused
It won't be updated until tomorrow. And thanks:)
DJ , I finally got back to my project and tried out the PWM 45% issue. It's fixed and you increased the resolution at the same time too, good job and thank you.
