Aimlbot icon Aimlbot — Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills. Try it →
Hi, When I try to use the sound servo control I get an exception message error, then ARC crashes. I'm at a loss? Steve
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** NAudio.MmException: BadDeviceId calling waveInOpen at NAudio.Wave.WaveIn.OpenWaveInDevice() at NAudio.Wave.WaveIn.StartRecording() at .(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at .OnLoad(EventArgs ) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.SetVisibleCore(Boolean value) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.Show() at . (Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr
Looks like a problem with your soundcard (or more to the point, a bad device ID on the soundcard). It's a windows issue, check your device manager for anything that isn't working properly.
I can confirm that Sound servo works OK in ARC 2013.06.15.00
Thanks for the quick reply, Device manager reported no errors and the sound card. And it's working. I can play sounds on it?
Steve
