BN-880 GPS Compass icon BN-880 GPS Compass — Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino. Try it →
You're going to have to bump up the 3.3 vdc to 5v with a regulator or leave it off and feed a higher separate voltage to the VCC and push the white button.
What would the wiring look like? Would you do the same thing in the old video other than the pressing the button?
If you use an external power supply It would look just like this. Your voltage source would go where the pic of the battery is and you would have no wire going to the 5V input port from the EZB. Pretend the picture of the EZB is a V4:
You'll know if you have the white button in the right position. One way the unit will power on and the other way it wont.
EDIT: updated image with proper grounding wires.
You dont need the 5v, just push the switch to use the onbpard regulator on the l298n.
Everything else as per the v3.
What about the enable pins? Do I solder to them like the ez-b v3 too?
If you want to solder them or you can use jumper cables if you want to like i did in my tutorial. Either way is fine.
ok thanks. Rich, If you don't mind, you helped a fair bit but Dave got to it first. So I'm going to give it to him.
You have no idea how hard it is to get in with the correct answer before Rich. ;) I think that's great and a good problem for a forum to have. :)
