Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Servo Motor Moves Back And Forth
I have a servo motor on my JD Humanoid robot that keeps adjusting about 10 degrees positive to negative. We notice it all the time, but it becomes very apparent when we try to set up the servo profile. It almost constantly adjusts back and forth. It is only one of the servo motors in the leg that does this. Is there a way to adjust the servo motor to fix this or does it just need to be replaced?
action, It sounds like the potentiometer in the servo is faulty, and the servo will have to be replaced.
Contact Us and link to this thread to see if the servo is covered under warranty.
Hi @action
Are you still experiencing any difficulties with the servo motor?
