Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Separate Power For Hd Servos
I have several HD servos to operate so I need external power supply. As I am inpatient to wait for ez bits, how do I go about supplying external power for these servos? I am okay with modifying the EZ-B v.3, I just don't know what I need to do. Help, anyone?
I have them attached in the smaller block of DIOs and was wondering if it was possible to only alter these, or if the alteration affected all DIOs?
#26
Part No. : D5733 . Voltage : 6 Volt . Capacity : 4.5 Ah . Chemistry : Sealed Lead Acid . Color : Black . Height : 4.17 in. . Width : 1.85 in. . Length : 2.76 in. . Start Temp. (Min) : 5 Deg. F . Start Temp. (Max) : 104 Deg. . Terminal : F1 . Weight : 1.83 lb. . UL Listed : Yes .Warranty : 1 Year .Order Code : UB645
Just bought two for 18 USD shipped New!
https://www.ebay.com/itm/120844794887?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
These will accept a low ampere charge well , sealed , gel/glass filled
#27
Thats the thing about those is easier charging .
#28
That's what I'm using on Omnibot, BOB. I have one in him and it works fantastic! I power the board, and also my motors and HD servos off this one battery. That way everything shares a common ground. Speaking of charging, what would I need to charge one of these batteries (haven't needed it yet)?
#30
AGM and gels last a lot longer if you slow charge them. Keeps from drying them out. I'm not sure about the voltage on a 6 v but 12v ones are 14.1. I would guess half at 7 volts and 6.2 to maintain J.W.
#32
A slow charge is 1.7 -2 volts over the battery rating at a rate between .7 and 1.5 ah . I bought a motorcycle computerized battery charger /maintainer that charges 1.5 amp from walmart. But I have 2 batteries so that's .75 ah per battery which is optimal slow charge. I leave them overnight. The charger I bought from walmart for 6 or 12v batteries was 20 bucks.
