Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
South Africa
Resolved Resolved by ptp!
Sdk: Speechsynthesis.Say(), Outputs To Pc Audio
Hi.
I am trying to output speech on the EZB using the SDK.
EZ_B.­Speech­Synth.­Say(­System.­String) outputs to PC Audio. The SDK documentation mentions that it plays to the "Default Audio Device".
Quote:
Method:EZ_B.­Speech­Synth.­Say(­System.­String) Say MSG to the default audio device
However, I can't find where to specify the EZB as the output device.
Thanks.
That method uses Windows default audio device.
if you want to output to the EZB:
public partial class Form1 : Form
    private EZB ezb;
    private void SayEzb(string text, bool wait)
        using (var ms = this.ezb.SpeechSynth.SayToStream(text))
            if (wait)
                this.ezb.SoundV4.PlayDataWait(ms);
            else
                this.ezb.SoundV4.PlayData(ms);
South Africa
I see. I thought It may have been something like that.
Thanks for the detailed example.
Cheers.
