I need a little guidance with getting the Script AI assistant to do what I need. Maybe I'm not asking correctly so it understands what I want.
I've been trying a while now to get it to change a bunch of soundboard controlCommands I currently have have that are using the old track number format to the new filename format.
For example I want it to change all of these commands in a script from
controlCommand("Dr_Smith", "Track_2")
to
ControlCommand("Dr_Smith", "Play", "Evil purpose.mp3");
I've already waisted 200 credits trying to figure this out. Oddly sometimes the AI will convert the commands like I want but it will only do about 8 out of 50 I have scripted. Other times it will tell me I need to give it the mapping to the file names. I thought this Script AI knew my project? If I provide mapping I could do this replacement myself.
This is kinda frustrating and expensive on waisted credits. Any suggestions on how I can talk to this AI to get it to do what I want?
Below is an example of one of the conversations I've had with the scripting AI assent trying to get it to simply replace my track numbers with the corresponding track names (file names) listed in the soundboard:
You:
replace all Track_# with Play + filename from that soundboard.
AI:
Which function(s) do you want me to update first (e.g., doDr_Smith, doR2D2, etc.), and do you already have the exact filenames for each Track_# in those soundboards?
You:
Update all functions. The exact file names for each track_# are the track titles corsponding to the track_# in thouse soundboards.
AI:
I can update every Track_# to Play "filename" but I need the actual file name for each track number in each soundboard (e.g., Dr_Smith Track_1 = "DrSmith.mp3", Track_2 = "Evil purpose.mp3", etc.).
Can you provide the track-number filename mapping for each soundboard (Dr_Smith, R2D2, Will, Don, Maureen, John, Tufeld, Judy, Wall_e, Penny, Hal9000, Bender, Robby, SFX, Soundboard v4), or confirm you want me to use index-based play (e.g., controlCommand("Dr_Smith", "Play", 1)) instead?
Yes - what you’re seeing is expected behavior, and the missing piece is not the filename format, it’s that the AI needs explicit track mappings or a better project description to safely rewrite every call.
Why it’s asking for mappings
ARC’s AI assistant can see your project context, but it does not automatically infer every soundboard track name from the old
Track_#calls unless those tracks are clearly described in the skill and the project metadata is rich enough.So when you say:
the AI knows you want a change, but it may not reliably know that Track 2 = "Evil purpose.mp3" unless:
The key limitation
The assistant can rewrite code, but it can’t guess the correct filename for every track number if that mapping is not clearly available to it. That’s why you only get partial conversions or a request for track mapping.
Best way to ask it
Instead of:
use a very specific request like:
Even better, if you want it to succeed in one pass, give it the mapping in a structured way.
Example prompt
That gives the assistant an unambiguous conversion table.
A better workflow to avoid wasting credits
Because you’ve already spent a lot of credits, I’d suggest this approach:
Option 1: Convert one soundboard at a time
Ask it to only update one soundboard name per run:
That reduces ambiguity and lets you verify the pattern before doing the next one.
Option 2: Use a script-aware search/replace yourself
If the filenames are already visible in ARC’s Soundboard skill, it may be faster to:
controlCommand("Dr_Smith", "Track_2")manually with the correctPlaycommandFor large scripts, though, the ARC AI Assistant can still be useful if you feed it the exact mappings.
Important: make the AI assistant work with your project setup
Per the ARC AI Assistant workflow, it helps a lot if you:
That way the assistant has better context when rewriting code.
See:
One more thing: use filename-based Play exactly
For Soundboard (EZB), the filename-based command should look like:
If you want scripts embedded in the audio timeline to run, you’d use the 4-parameter form:
My recommendation
If you want, paste one soundboard’s full track list and I can help you craft the exact prompt that will make the ARC AI Assistant do a clean full conversion without wasting more credits.
Or, if you paste one of your scripts here, I can help you convert the
Track_#calls into a proper JavaScript version using the filename-basedPlaycommands.
