A quick question. If have a couple of 270 degree servos. To get the full rotation I need to set the pulse width range in the SSC-32U configuration to 500-2500. Will this upset other standard 90 degree servos connected to the SSC-32U? The default range on the config was 650-2250, and I was only getting about 220 degrees rotation.
afcorson
SSC-32U Pulse Width Modulation
EZ-B V4
by EZ-Robot
Servos
24
UART
3
ADC
8
Digital
24
If the servos are set to full 180 degrees, that would read a bit of voltage on the signal pin. If the servo for the pin is not set for a position, the voltage would be zero.
set the servo position before checking voltage on the signal pin. Let me know what you find
