Irobot Roomba Legacy icon Irobot Roomba Legacy — Legacy iRobot Discovery and 4xxx control via EZB software-serial (D0), supports Arduino/EZ-Robot, adjustable baud rate; not for hardware UART/USB Try it →
Robot Function Priority Stack
This is my list for a robot function priority stack. Opinions will vary and thats what I am looking for:) At the top of the list is
EZ-Builder:) Highest level overall manager
EZ-Board...naturally:) In order of highest prioroity
Voice Recognition/keyboard/touch screen smoke/co2 detection intruder/person alarm/acknowledgement (motion)
Electrical system, voltage and current monitoring component heat fuse alarms
Tilt(falling), Vibration(earth quake,door knocking, (stop shaking me:) ) Motors Motor positioning reporting Camera GPS/line tracking/ roommaping (Lidar?) Light detection (Good morning,or NOT) Temp/Humidity sensors (Turn up the heat in here, and it seems like rain) LED effects (BlinkM and others) LCD/OLED/TFT/ Tablet for Teleprompting(Cant remember all my commands:) )
All comments welcome. Omissions or deletions?
by component heat, you mean monitoring it?
light detection could be hard to configure.
as ARC is getting older, the camera tracking is improving so I think the intruder/person alarm/acknowledgement (motion) will work out.
@Technopro! YUP ..monitoring heat from an IC can be useful for possible overcurrent and device failure ie too much dust etc:) There are light sensitive LEDs ordevices ...Like a photo cell (96 cents) from adafruit "CdS cells are little light sensors. As the squiggly face is exposed to more light, the resistance goes down. When its light, the resistance is about 5-10K?, when dark it goes up to 200K?. To use, connect one side of the photo cell (either one, its symmetric) to power (for example 5V) and the other side to your microcontroller's analog input pin. Then connect a 10K pull-down resistor from that analog pin to ground. The voltage on the pin will be 2.5V or higher when its light out and near ground when its dark.":)
