Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Robot Direction Movement Faults.
Whenever I press the keys to move my robot forwards, backwards, left, and right- it gets the directions mixed up. For example- when I press the forward button, my robot just spins in a circle. when I press the backward button, it just spins the other direction. When I click the left and right keys, it goes forward and reverse...:vS If anyone could help me resolve this tonight, that will be great. Keep up the good work guys ;v)
How is it set up?
It sounds like you have the ports set incorrectly in the config for the movement panel. Adjust them until the directions are correct.
