Like all operating systems, click (touch) the title bar and drag the control around the screen. To delete the control, drag on the trash bin.
There is a tutorial in the learn section under activities.
Hi JD, Thanks for the quick reply. I was touching the actual step box, not the title bar...:)
The tutorial you mentioned focused on the Windows based tool and I had no issues with that.
One quick one, if I may, is that an easy way to slow down JD's motions as he tends to frighten grandchildren
Thanks, Frank
