Sighthound Cloud API icon Sighthound Cloud API — Cloud-based detection of people and faces in robot camera video; returns locations, gender, age, pose, emotion, plus 68-point facial landmarks. Try it →
Relays Turn On, But Not Off
Alright. My dewy build is almost finished, but I have hit a problem with the relays I'm using. They require at least 1.5v to activate them, and then nothing to deactivate them.
Using a set digital control, I can turn them on, but turning the control off doesn't deactivate the relays.
Why would this be? Does setting the digital port off not set the voltage low?
How else can I activate them and deactivate them with the ez-b if not in this manor?
if you like breadboards this is the cheapest circuit:
https://www.digikey.com/product-detail/en/texas-instruments/SN74HCT245N/296-1612-5-ND/277258
has 8 ports can convert 8 x 3.3v to 5v (unidirectional) but the cost can get more expensive with shipping costs ($4 to $9)
if you like "legos":
these is the cheapest i found in the ebay:
https://www.ebay.com/itm/10PCS-IIC-I2C-Logic-Level-Converter-Bi-Directional-Module-5V-to-3-3V-For-Arduino-/151910206546
each circuit has 4 ports, they wrote i2c because most people use them to interface arduinos 5v with 3.3v i2c devices, but they are bidirectional they can convert the opposite way.
There is a high side & low side, you can use them also to convert to 1.8v (intel edison)
if you don't trust ebay vendors you can get this one from sparkfun:
https://www.robotshop.com/en/logic-level-converter-bidirectional.html
also has 4 ports.
#74
Thanks for the info. I ordered 1 and once it is here I will play.
Thanks,
