Omron HVC-P2 (Second Camera) icon Omron HVC-P2 (Second Camera) — Windows ARC plugin for Omron HVC-P/HVC-P2: Python-based face/body/hand detection, gaze, age/gender, expressions and recognition; dual-camera support. Try it →
Record Function
Hello DJ-
I had an idea that I think might be a cool addition, and I don't think it would be too hard to implement..
I was playing around with the "Touch Map" control to control my robot to travel following the spline and this is what made me think of a "record" function.
What I'd like to see is a "record" function that ARC records the movements of your robot and then plays them back.
For example, If I attached a broom brush to the front of my robot, I could use a standard "keyboard control" to steer my robot around and sweep the kitchen. As I'm manually moving the robot around, EZ_Builder is recording these movements (and time) into a script or something that I can then play back at a later time, and it would follow the exact plan I had recorded earlier.
Make sense?
Any ideas? Would this be easy to do?
Brad
Well that does sound like a excellent idea, basically you manually control the robot and ARC remembers the script so you can trigger those scripts anytime instead of trying to figure out everything by trail and error.
Omg ... Will you marry me. Ha ha jk
