Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
Questions With Rotational Servo Speed On Adventure Bot
When I load the example project, I get an Auto Position Control that includes directional arrows. However, when I press Forward or Reverse, only one servo moves. If I press Right or Left, both servos move as expected in opposite directions After reading the "Calibrate Continuous Rotation servo Adjust Speed" tutorial and watching the video, I added the "Continuous servo Movement" Control which required the removal of the Auto Position Control. Per the video, I changed my stop values from the default 108 to 90 and clicked Test on both Stops, with the "Use" checked. I was able to stop the movement as shown in the video The next step adjusting speed, with the "Use" unchecked. Unlike the video, I was only able to slow the speed a very small amount. My servos would only move at 95 or greater or 82 or less not the closer numbers shown in the video.
My questions are:
  1. Why can’t I set the slow speed?
  2. Why was the Auto Position control in the example?
  3. Am I now supposed to remove the control I added and put back in the Auto Position control I read many other posts on issues with rotational servo speed issues, but didn’t find a solution
Thanks, Frank
okay, let me get back to you tomorrow
im having replacement servos sent to you. I believe the ones you have are faulty. Apologies, the replacements will have proper speed control ability.
@djsures The new replacement servos work great!
I really enjoy have a wide range of speed control now.
Thank you very much Frank
