EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
Question About Alternate Powered Servos
I have several servos tied into an alternate power source with the signal wire coming from the EZ-B. Question: When those servos are tied into the alternate power do they draw any current when the signal wire is not energized (ie. the EZ-B is turned off)? I want to know if I need to put an on/off switch in line with the power to those servos?
Thanks, Bret
Put a offswitch on the ground of your batt. They can draw tiny bits because the servos controller is always waiting on.a signal to move.
