Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Pwm Slider Question Pwm On D4 Turns D14 On And Off
I am finding PWM slider issues, here's one that I have posted in the cloud, (is this the proper way to request help?) When the PWM slider on d4 is moved up to 100%, d14 output goes high. Then when I slide the d4 PWM slider down to 0% d14 then output goes low. This happens across multiple software revs, board os and 2 different v3 boards. This can be observed by attaching leds to these ports. I am wondering is this the right place to point these issues out? If not please guide me, this forum stuff is new to me.
#17
I will test it tonight. I have a couple more issues. Should I start a new thread for these? Thanks
#18
DJ, WOW, Everything works! It seems when you solve a problem you go the extra mile. Thanks again:)
#19
There's a little speed increase in the latest firmware as well - not sure if you noticed:)
#20
I don't know what speed you are speaking of. I did notice the resolution has increased a lot though.
