Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Pulling A Jpeg From Http Server Control Results In Not A Jpeg Error In Roborealm
I am using the read_HTTP module in Roborealm to pull the static image provided via the HTTP Server control in ARC.
When I try Roborealm says it's not a valid JPEG image.
Troubleshooting done:
  1. Using a browser I can access the image in ARC's HTTP server just fine.
  2. Using a different website that provides an image the read_HTTP module in Roborealm works fine.
There is some kind of incompatibility between Roborealm and ARC and how the image is either being sent or read.
Since I do not know which application is the cause of the issue I am requesting assistance from both sites.
Any help would be appreciated.
You might need to contact RoboRealm to understand why their software is not able to read a JPEG image over HTTP
After posting here I did some more testing with fiddler and like you stated ARC seems to be sending a plain old JPEG back so I contacted them and they are looking into it.
Thanks for your reply.
awesome ! Let me know the results of their findings. I'm always willing for integration between neat projects like roborealm
