Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Packet Comm With Iotiny
Can the camera port on the ioTiny be used for two-way serial communications, or is the ioTiny limited to only simple (one-way) serial comms?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
The camera port on the EZ-B IoTiny is specifically designed for the camera connection and cannot be used for two-way serial communications. The IoTiny does support serial communication, but it is limited to transmit only (one-way). Each digital port on the IoTiny can transmit serial data. However, they do not support receiving data, making the communication one-way. For more detailed information, you can refer to the EZ-B IoTiny documentation in the support section on the Synthiam website.
