EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Not a.guide really , but we can explain to.to do.things and I have tons of pics. What are you wanting your robot to do?
Didn't realize i needed another board to run the motors? Where do i connect my eye lights?
Motors i mean omnibots wheels
Ezb only provides signals to coordinate other motors or servos , motors don't connect to it directly. For a omnibot you want to buy a L298 Hbridge motor control. It recieves signals to run the motors forward or back at the desired speed.
Eye lights you will remove and replace them with either 5mm LEDs or 10mm , you can Connect a single led to one single digital port on ezb , so two eyes would use two ports.
Ok i am on the right path, I ordered the Hbridge already and i will pick up lights later in week. Any pictures and advice you can give me?
Thanks
Welcome cybersarg! Here is a link to my omnibot project with some helpful info:
Linky and a link to my finished product. Linky 2 Hope that helps some. And Pics, we love Pics!
What Power supply should i use to power the wheels?
I just used the standard 6V battery that originally came in the omnibot (you can get them for 10 bucks on the internet). I used that to power everything, the board, my drive, all of it from the one battery.
