what is the length of the omnibot 5402 right arm? interested in frankenstiening up my rad project AleX
— Edited
Smart Variable Watcher
— Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length
The whole arm or just the top or bottom sections?
I know that either the whole arm or the upper arm is 300mm long roughly. They should just about be the right size on a RAD.
If you look in this picture you can see the RAD is around the same size as Melvin, which is basically a 5402 torso
ok thanks. theres a guy who tore his omnibot apart and is selling it for parts. hmmmmmmmm.... eyeroll
Omnibot arm next to RAD torso
You decide
wow! there bigger than I thought! how big is the omnibot 2000?!?(not the arm, the whole robot)
That's from a 5402, the 2000 is bigger.
It might work with the 5402 arms, just make sure they bend at the elbow before lowering the arm down otherwise they will hit the base.
yea. I think I will try to use a different arm.
I learned one thing, and its that I got the small robot.
