DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Resolved Resolved by Athena!
Obstacle scan only once
Obstacle Scan Only Once
#include <AccelStepper.h>#include <MultiStepper.h>
static const uint8_t UART_HEADER = 0xA5;
// ARC -> Arduinostatic const uint8_t CMD_STOP_MOTORS = 0x01;static const uint8_t CMD_ACTUAL_BEARING = 0x03;static const uint8_t CMD_RIGHT_PIVOT = 0x04;static const uint8_t CMD_LEFT_PIVOT = 0x05;static const uint8_t CMD_WAYPOINT_DATA = 0x06;
// Arduino -> ARCstatic const uint8_t RSP_NAV_ACK = 0x10;static const uint8_t RSP_TOTAL_STEPS = 0x11;static const uint8_t RSP_DESIRED_BEARING = 0x12;static const uint8_t RSP_OBS_SCAN_REQUEST = 0x13;
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);MultiStepper multiStepper;
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_PAYLOAD };ParserState state = WAIT_HEADER;
uint8_t currentCmd = 0;uint8_t payload[32];uint8_t payloadIndex = 0;uint8_t expectedLength = 0;
int RUN = 0;
uint32_t totalStepsTaken = 0;uint32_t combinedStepsDesired = 0;uint32_t pathTotalDistance = 0;uint32_t oppositeDistance = 0;uint8_t bearingAlignment = 0;uint16_t reflectorBearing100 = 0;uint8_t sensorPrime = 0;uint16_t waypointDesiredBearing100 = 9000;uint16_t waypointActualBearing100 = 9000;uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;uint16_t desiredBearing100 = 9000;uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;int16_t bearingDiffRamped = 0;
bool obstacleScanRequested = false;bool scanNeutralMode = false;
uint32_t nextScanStep = 10500;const uint32_t scanIntervalSteps = 10500;
uint16_t currentSpeed = 0;uint16_t normalSpeed = 800;
uint16_t readUInt16LE(const uint8_t* data) {  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);}
uint32_t readUInt32LE(const uint8_t* data) {  return (uint32_t)data[0]    | ((uint32_t)data[1] << 8)    | ((uint32_t)data[2] << 16)    | ((uint32_t)data[3] << 24);}
void writeUInt16LE(uint16_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));}
void writeUInt32LE(uint32_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));  Serial3.write((uint8_t)((value >> 16) & 0xFF));  Serial3.write((uint8_t)((value >> 24) & 0xFF));}
void sendHeaderAndCmd(uint8_t cmd) {  Serial3.write(UART_HEADER);  Serial3.write(cmd);}
void sendNavAck() {  sendHeaderAndCmd(RSP_NAV_ACK);  Serial.println("TX: NAV ACK");}
void sendTotalSteps(uint32_t steps) {  sendHeaderAndCmd(RSP_TOTAL_STEPS);  writeUInt32LE(steps);  Serial.print("TX: TOTAL STEPS = ");  Serial.println(steps);}
void sendDesiredBearing(uint16_t bearing100) {  sendHeaderAndCmd(RSP_DESIRED_BEARING);  writeUInt16LE(bearing100);  lastSentDesiredBearing100 = bearing100;  Serial.print("TX: DESIRED BEARING x100 = ");  Serial.println(bearing100);}
void sendObstacleScanRequest() {  sendHeaderAndCmd(RSP_OBS_SCAN_REQUEST);  Serial.println("TX: OBSTACLE SCAN REQUEST");}
void resetStepperPositions() {  LeftFrontWheel.setCurrentPosition(0);  LeftBackWheel.setCurrentPosition(0);  RightFrontWheel.setCurrentPosition(0);  RightBackWheel.setCurrentPosition(0);}
void resetNavigationState() {
 resetStepperPositions();
  totalStepsTaken = 0;  desiredBearing100 = 9000;  actualBearing100 = 9000;  lastSentDesiredBearing100 = 0xFFFF;  bearingDiffTarget = 0;  bearingDiffRamped = 0;  obstacleScanRequested = false;  scanNeutralMode = false;  nextScanStep = scanIntervalSteps;  currentSpeed = 0;  RUN = 0;  Serial.println("Navigation state reset");Serial.print("desiredBearing100:  ");Serial.println(desiredBearing100);Serial.print("totalStepsTaken:  ");Serial.println(totalStepsTaken);Serial.print("combinedStepsDesired:  ");Serial.println(combinedStepsDesired);Serial.print("pathTotalDistance:  ");Serial.println(pathTotalDistance);
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {  LeftFrontWheel.setSpeed(leftSpeed);  LeftBackWheel.setSpeed(leftSpeed);  RightFrontWheel.setSpeed(rightSpeed);  RightBackWheel.setSpeed(rightSpeed);}
void stopMotors() {  LeftFrontWheel.stop();  LeftBackWheel.stop();  RightFrontWheel.stop();  RightBackWheel.stop();  LeftFrontWheel.setSpeed(0);  LeftBackWheel.setSpeed(0);  RightFrontWheel.setSpeed(0);  RightBackWheel.setSpeed(0);  Serial.println("Action: stopMotors()");}
void pivotRight(uint16_t steps) {  long positions[4];  positions[0] = LeftFrontWheel.currentPosition() + steps;  positions[1] = LeftBackWheel.currentPosition() + steps;  positions[2] = RightFrontWheel.currentPosition() - steps;  positions[3] = RightBackWheel.currentPosition() - steps;  multiStepper.moveTo(positions);  while (multiStepper.run()) { }  totalStepsTaken += steps;  stopMotors();  sendTotalSteps(totalStepsTaken);  resetNavigationState();}
void pivotLeft(uint16_t steps) {  long positions[4];  positions[0] = LeftFrontWheel.currentPosition() - steps;  positions[1] = LeftBackWheel.currentPosition() - steps;  positions[2] = RightFrontWheel.currentPosition() + steps;  positions[3] = RightBackWheel.currentPosition() + steps;  multiStepper.moveTo(positions);  while (multiStepper.run()) { }  totalStepsTaken += steps;  stopMotors();  sendTotalSteps(totalStepsTaken);  resetNavigationState();}
void beginForwardNavigation() {  RUN = 1;  currentSpeed = 0;  bearingDiffRamped = 0;  obstacleScanRequested = false;  scanNeutralMode = false;  nextScanStep = scanIntervalSteps;}
void computeDesiredBearing() {  if (bearingAlignment == 0) {    desiredBearing100 = 9000;    return;  }
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0) {    if (pathTotalDistance > totalStepsTaken) pathDistanceRemaining = pathTotalDistance - totalStepsTaken;  } else {    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;    if (pathTotalDistance > remainingSteps) pathDistanceRemaining = pathTotalDistance - remainingSteps;  }
  float tangent = (float)oppositeDistance / (float)pathDistanceRemaining;  float deg = atan(tangent) * 180.0 / PI;  desiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {    sendDesiredBearing(desiredBearing100);  }}
void updateBearingDiff() {  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffRamped < bearingDiffTarget) {    bearingDiffRamped += 10;    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;  } else if (bearingDiffRamped > bearingDiffTarget) {    bearingDiffRamped -= 10;    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;  }}
void runForwardLoop() {  if (currentSpeed < normalSpeed) {    currentSpeed += 10;    if (currentSpeed > normalSpeed) currentSpeed = normalSpeed;  }
  computeDesiredBearing();  updateBearingDiff();
  int leftSpeed = currentSpeed;  int rightSpeed = currentSpeed;
  if (!scanNeutralMode) {    int correction = bearingDiffRamped / 10;    leftSpeed -= correction;    rightSpeed += correction;  }
  setAllMotorSpeeds(leftSpeed, rightSpeed);
  LeftFrontWheel.runSpeed();  LeftBackWheel.runSpeed();  RightFrontWheel.runSpeed();  RightBackWheel.runSpeed();
  totalStepsTaken =    abs(LeftFrontWheel.currentPosition()) +    abs(LeftBackWheel.currentPosition()) +    abs(RightFrontWheel.currentPosition()) +    abs(RightBackWheel.currentPosition());
  if (!obstacleScanRequested && totalStepsTaken >= nextScanStep) {    sendObstacleScanRequest();    obstacleScanRequested = true;    scanNeutralMode = true;    nextScanStep += scanIntervalSteps;  }
  if (totalStepsTaken >= combinedStepsDesired && combinedStepsDesired > 0) {    stopMotors();    sendTotalSteps(totalStepsTaken);    resetNavigationState();  }}
uint8_t getExpectedLength(uint8_t cmd) {  switch (cmd) {    case CMD_STOP_MOTORS: return 0;    case CMD_ACTUAL_BEARING: return 2;    case CMD_RIGHT_PIVOT: return 2;    case CMD_LEFT_PIVOT: return 2;    case CMD_WAYPOINT_DATA: return 18;    default: return 0xFF;  }}
void handleWaypointPacket(const uint8_t* data, uint8_t len) {  if (len != 18) return;
  pathTotalDistance = readUInt32LE(&data[0]);  combinedStepsDesired = readUInt32LE(&data[4]);  oppositeDistance = readUInt32LE(&data[8]);  bearingAlignment = data[12];  reflectorBearing100 = readUInt16LE(&data[13]);  sensorPrime = data[15];  waypointDesiredBearing100 = readUInt16LE(&data[16]);  waypointActualBearing100 = actualBearing100;  trackDir = 0;
  desiredBearing100 = waypointDesiredBearing100;  actualBearing100 = waypointActualBearing100;
  sendNavAck();  beginForwardNavigation();}
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {  switch (cmd) {    case CMD_STOP_MOTORS:      stopMotors();      sendTotalSteps(totalStepsTaken);      resetNavigationState();      break;
    case CMD_ACTUAL_BEARING:      if (len == 2) {        actualBearing100 = readUInt16LE(data);      }      break;
    case CMD_RIGHT_PIVOT:      if (len == 2 && RUN == 0) pivotRight(readUInt16LE(data));      break;
    case CMD_LEFT_PIVOT:      if (len == 2 && RUN == 0) pivotLeft(readUInt16LE(data));      break;
    case CMD_WAYPOINT_DATA:      if (RUN == 0) handleWaypointPacket(data, len);      break;  }}
void processIncomingByte(uint8_t b) {  switch (state) {    case WAIT_HEADER:      if (b == UART_HEADER) state = WAIT_CMD;      break;
    case WAIT_CMD:      currentCmd = b;      expectedLength = getExpectedLength(currentCmd);      if (expectedLength == 0xFF) {        state = WAIT_HEADER;      } else if (expectedLength == 0) {        handlePacket(currentCmd, nullptr, 0);        state = WAIT_HEADER;      } else {        payloadIndex = 0;        state = WAIT_PAYLOAD;      }      break;
    case WAIT_PAYLOAD:      payload[payloadIndex++] = b;      if (payloadIndex >= expectedLength) {        handlePacket(currentCmd, payload, expectedLength);        state = WAIT_HEADER;      }      break;  }}
void readIncomingUart() {  while (Serial3.available() > 0) {    processIncomingByte((uint8_t)Serial3.read());  }}
void setup() {  Serial.begin(115200);  Serial3.begin(115200);
  LeftFrontWheel.setMaxSpeed(2000);  LeftBackWheel.setMaxSpeed(2000);  RightFrontWheel.setMaxSpeed(2000);  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);  LeftBackWheel.setAcceleration(800);  RightFrontWheel.setAcceleration(800);  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);  multiStepper.addStepper(LeftBackWheel);  multiStepper.addStepper(RightFrontWheel);  multiStepper.addStepper(RightBackWheel);
  resetNavigationState();  Serial.println("Arduino_v5 ready");}
void loop() {  readIncomingUart();  if (RUN == 1) {    runForwardLoop();  }}
This is an Arduino sketch that communicates over Serial3 using a simple UART protocol (header 0xA5). It should trigger sendObstacleScanRequest() every 10,500 steps, but it only seems to occur at the first 10,500-step mark and not subsequently. Is this line of code correct?
For reference, Serial3 is the serial port used to communicate with ARC (or a host controller/EZB) in this setup.
Thanks, Jack
USB
Digital 21
Script by Synthiam
Task Script by Synthiam Inc.
Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
Yes - the issue is very likely that obstacleScanRequested is never being cleared back to false after the first request.
Right now your logic does this:
That means:
  1. At 10,500 steps, it sends the request
  2. obstacleScanRequested becomes true
  3. On the next loop, the condition can never pass again because you never set it back to false
Why it only happens once
Your code increments nextScanStep, but the !obstacleScanRequested gate blocks future requests forever.
Fix options
Option 1: Reset the flag when the scan response is received
If ARC or your host sends a response back after the scan, that response handler should clear the flag:
That would allow the next 10,500-step trigger to fire.
Option 2: Remove the flag entirely
If you only want one request per interval, the nextScanStep check is enough by itself:
if (totalStepsTaken >= nextScanStep) {
This works only if runForwardLoop() runs often enough and you don’t need a "wait for response" lockout.
Option 3: Use a response/timeout state machine
A safer approach is:
  • send request
  • set obstacleScanRequested = true
  • wait for reply
  • when reply arrives, clear obstacleScanRequested
  • optionally start a timeout fallback in case no reply arrives
That’s usually the best pattern for serial robot navigation.
One more thing to check
You calculate:
If your steppers are not all moving the way you expect, this could jump in unexpected ways. But that would not explain "only once" as clearly as the boolean flag does.
If you want repeated obstacle scan requests every 10,500 steps, I’d start with this:
Then, wherever you process the scan reply:
ARC side note
If this Arduino is talking to ARC over Serial3, make sure your ARC side skill is reading the custom protocol consistently. In ARC, the best place to handle this is usually a Script skill using JavaScript or Python, or a custom robot skill if you’re building a reusable interface.
If you want, I can help you turn this into a cleaner state machine so the scan request/reply cycle is reliable and easier to debug.
Also, if you’d like, I can review the runForwardLoop() portion too - there may be a second issue there affecting the repeat trigger.
@Athena. Please turn this into a cleaner state machine so the scan request/reply cycle is reliable and easier to debug. Also, please review the runForwardLoop() portion too - there may be a second issue there affecting the repeat trigger. Thanks. Jack
Absolutely - a cleaner scan request / reply state machine will make this much more reliable and much easier to debug.
What’s going wrong right now
Your current logic mixes:
  • forward motion
  • bearing correction
  • scan trigger timing
  • "waiting for reply" locking
  • scan neutral mode
That makes it easy for one boolean to block the whole cycle.
The biggest improvement is to replace the single flag approach with an explicit scan state.
Suggested scan state machine
Use an enum like this:
enum ScanState {
  SCAN_IDLE,
  SCAN_REQUESTED,
  SCAN_WAITING_REPLY
ScanState scanState = SCAN_IDLE;
Then track:
  • nextScanStep when the next scan should happen
  • scanRequestStep when the request was sent
  • scanTimeoutMs fallback if reply never arrives
Cleaner flow
1) When moving forward
  • if you reach the next scan threshold and you are not already waiting:
    • send scan request
    • enter SCAN_WAITING_REPLY
    • record the step count and timestamp
2) When scan reply arrives
  • process the scan data
  • clear the wait state
  • optionally resume normal steering
3) If no reply arrives in time
  • log a timeout
  • optionally continue moving or retry
Example implementation
Here is a cleaner version you can adapt.
Global state
enum ScanState {
  SCAN_IDLE,
  SCAN_WAITING_REPLY
uint32_t scanRequestStep = 0;
uint32_t scanRequestTimeMs = 0;
const uint32_t scanTimeoutMs = 1000;
Send scan request
void requestObstacleScan() {
  scanState = SCAN_WAITING_REPLY;
  scanRequestStep = totalStepsTaken;
  scanRequestTimeMs = millis();
  Serial.print("SCAN REQUEST SENT at step ");
  Serial.println(scanRequestStep);
Handle scan reply
When your reply comes back from ARC or another controller, call something like this:
void handleObstacleScanReply() {
  Serial.println("SCAN REPLY RECEIVED");
  nextScanStep = totalStepsTaken + scanIntervalSteps;
  Serial.print("Next scan scheduled at step ");
  Serial.println(nextScanStep);
If your reply includes data, add it into that function.
Timeout check
void updateScanTimeout() {
  if (scanState == SCAN_WAITING_REPLY) {
    if (millis() - scanRequestTimeMs > scanTimeoutMs) {
      Serial.println("SCAN TIMEOUT");
Cleaner scan trigger in runForwardLoop()
Replace this:
with this:
if (scanState == SCAN_IDLE && totalStepsTaken >= nextScanStep) {
  requestObstacleScan();
That’s the key improvement.
Review of runForwardLoop() logic
Your current loop has a likely second issue:
Why this may be a problem
That value is the sum of all 4 wheels, not the actual distance traveled by the robot.
If each wheel moves 10,500 steps, this total becomes around:
42,000
That means your threshold logic may be firing earlier or later than expected depending on how the motors are configured.
Better approach
Use one representative wheel or average the wheels:
totalStepsTaken = (abs(LeftFrontWheel.currentPosition()) +
                   abs(RightBackWheel.currentPosition())) / 4;
If all 4 steppers are mechanically synchronized, averaging is usually more meaningful than summing.
Another likely issue: stopMotors() and resetNavigationState()
In your pivot functions you do:
stopMotors();
But in resetNavigationState() you set:
RUN = 0;
So if a pivot or stop happens, you are completely resetting the navigation state. That’s fine if it’s intentional, but it can interfere with repeat scanning if you expect the robot to continue the same run after a pause or correction.
If the robot should continue navigating after a scan, you should not fully reset navigation on every scan event.
Use these separate functions:
  • beginForwardNavigation()
  • requestObstacleScan()
  • handleObstacleScanReply()
  • updateScanTimeout()
  • runForwardLoop()
  • stopNavigation() for full reset only
That keeps each responsibility isolated.
Suggested runForwardLoop() skeleton
  if (RUN != 1) return;
  updateScanTimeout();
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
    stopMotors();
Helpful debug prints
These will make the behavior much easier to trace:
Serial.print("RUN=");
Serial.print(RUN);
Serial.print(" totalStepsTaken=");
Serial.print(totalStepsTaken);
Serial.print(" nextScanStep=");
And for scan state:
Serial.print("scanState=");
Serial.println((int)scanState);
Important note about ARC
Since this protocol is between your Arduino firmware and ARC, I’d recommend keeping the scan reply handling in one place only:
  • Arduino sends request
  • ARC replies with scan data
  • Arduino receives reply and calls handleObstacleScanReply()
If you want, I can also help you write the ARC JavaScript side that listens for RSP_OBS_SCAN_REQUEST and sends the response back cleanly.
Next step
If you paste your full runForwardLoop() function and the ARC-side serial handling, I can rewrite both into a complete working version with:
  • a proper state machine
  • debug logging
  • timeout handling
  • reply handling
  • cleaner step threshold logic
@Athena Very Helpful. Thank you. Jack
