Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Numeric Keypad - Mobile Builder
Good Afternoon,
I am looking to create a numeric keypad within ARC. I want to pre-program a script for example 133. How do you combine the numbers into a string value, and that value is a number?
Thanks WayneA
#25
What does the following below mean?
ELSE
 $number=$number*Power(10,1)
 $number=$number+$currentnum
 $order++
EndIf
What if you wanted to shift or move down the input data to another string variable? Would that depend on the $order string variable right?
IF ($order=0)
$number=$currentnum
$order++
$order++ means you are adding the number one to it right
Trinidad/Tobago
Twitter YouTube
#26
The first section of code can be replaced to
ELSE
 $number=$number*10
 $order++
EndIf
you don't need the power function... but what this does is when you press a key it will move the first number entered to a new column and then add the new number pressed.
so if you press 1 the entered number is 1 if you press 2 the entered number is now 10+2=12 if you press 3 the entered number is now 120+3=123
that way it is just like a calculator when entering numbers on the keypad.
the entered number is stored in $number you can store this value in a different variable if you wish but it would be an integer to start not a string. and order++ increases the amount of digits stored in $number... so by resetting order to 0 you enter a new number into the $number variable.
#27
How would you store $number into another variable after you are done entering it?
a script to look at the count?
#28
$newvariable = $oldvariable
So...
$anothervariable = $number
Trinidad/Tobago
Twitter YouTube
#29
You would create an enter button that signifies that you are done entering a number and then you would do as Rich said to store the value in another variable.
