Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
New Inmoov Builder Power Questions
For the inmoov builders here. For power distribution I am thinking of using a tiny and EZ/4 plus a SSC-32 spreading the BB805's out over the 3 boards. I have a 60A power supply to feed the boards. I understand the EZ will do 5A each so 2 805s on each EZ and a few small servos and the rest on a SSC-32. Do you think this is a way to go? . Right now 3 BB805's will reset a tiny with a 2A supply but it will run 2 of them.
Thanks
Richard R has the most experience using the ssc-32 with an InMoov here. I dont believe it will be an issue but I would wait for a responce from him.
The SSC-32 can handle 5A x 2 continuous (20 amp for short bursts).... Meaning 5A for the pins 0 -15 and 5A for pins 16 -31... So 5A a side... Hope that helps...
Richard do you use a SSC-32 with a inmoov, are you happy with it? Thanks
