MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
Sounds like you have connected the LED to the VCC and Ground not the Signal and Ground.
Connect the anode of the LED to the Signal of the digital port. Connect the cathode side of the LED to the Ground of the digital port.
In ARC add the Digital Set Digital control.
Set the Port in the Set Digital control to that of the LED
Click on the button to turn on and off.
Refer to the LED Hardware Tutorial for more info.
OK thanks rich simple enough.that should help.
There's not much chance of losing me dude:)
Although I am away next Tuesday to Thursday (but guaranteed I'll still log on...)
Netherlands
Twitter YouTube
Maybe you should add a current limiting resistor, you don't want to burn one of your EZ-B's outputs :D
@Niek
Quote:
The one thing to notice is an LED connected to a digital port on the EZ-B does not need a resistor. This is because the digital ports on the EZ-B have pull-up resistors built-in.
There was a discussion on this a couple of months ago here
Netherlands
Twitter YouTube
@Rich
A pullup resistor is not the same as a current limiting one.
But hey, if DJ said it won't do any damage I believe him.
Thanks guys ! Working great !now I need help with a better script to make the leds to come on n off when the robot talk.all I ve done so far is to make it blink by: set(dig port,on) and sleep etc.. but that s as far as I have ventured to do so far.any fun ideas?
