Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
Resolved Resolved by Rich!
Need Help On Hbridge, Please
OK, I have:
Left trigger A 16 Left trigger B 17 Right trigger A 18 Right trigger B 19
When I hit forward, it goes to the right. when I hit backward, it goes to the left. when I hit Right it goes forward. and when I hit Left it goes backwards.
How can I fix this?
Thanks in Advance.
In ARC change your ports for the H-Bridge.
Think logically, since it turns right when you hit forward you know the right motor must be spinning backwards when it should spin forwards. This indicates the right triggers are around backwards. This is confirmed by the other behaviour.
So change Right Trigger A to 19 and Right Trigger B to 18, that should fix it.
Additional info For information (in case you wanted to know how to figure it out) To move forwards the motors must; Left: Forwards Right: Forwards
To move reverse the motors must; Left: Reverse Right: Reverse
To move left the motors must; Left: Reverse Right: Forwards
To move right the motors must; Left: Forwards Right: Reverse
So, if it's turning right when it should go forwards the motors are; Left: Forwards Right: Reverse When they should be; Left: Forwards Right: Forwards So the right triggers appear to be backwards. Swap them around and check.
Once again, Thank You for sharing your genius with us.
Now it moves forward as directed and backwards as told. Since I put the top on in reverse, the backwards goes way faster than the forward. When it tries to move Left, it moves so slowly. when it tries to move Right, it just gives it a BUMP in the right direction. But you have solved for the direction problem. It could be that my batteries are low.
Thank You!:)
I think they have Kings and qweens in the UK. Rich gets to choose which he wants to be.
We have a prime minister who I guess would be the equivalent of president. But it's probably not a good idea to give me control of a country!
I'm happy to share what knowledge I have:)
Isn't that what your Royals are for also? Sharing the knowledge they've attained throughout their lineage? You can be our Royalty here Rich. ;)
Long live the King of EZB forum!
:D
