Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Need Help
Bonjour,
Désolé mais je suis Français et je ne parle pas suffisamment bien l'anglais pour écrire dans cette langue.
J'ai récemment fait l'acquisition d'un robot JD Humanoïde mais il n'y a pas de :
  • notice de montage
  • notice d'utilisation, mode d'emploi, etc.
  • de cd avec le logiciel de programmation Comment peut on se procurer tous ces éléments (en anglais et/ou en français) ? Merci d'avance pour vos réponses. Cordialement Patrice 7527
Thank you I need more than that but it's a beginning
what are you looking for
Conversion:
Quote:
Hello,
Sorry but I'm French and I do not speak English well enough to write in that language.
I recently acquired a JD Humanoid robot but there is no :
  • Assembly instructions
  • User guide, user manual, etc.
  • Cd with the programming software How can I get all these elements (in English and / or French ) ? Thank you in advance for your answers. cordially Patrice 7527
Use the Learn section, it shows how to use your robot. User guide etc. is the learn section and the software. The software is constantly updated therefore a CD version would be of no use. Download ARC from the website's software section.
Following the tutorials in the Learn section will answer all of your questions.
patrice
what are you using ,a pc win7 or win8 ?
Thank you for your translation. I shall wish to get myself documentations under paper shape either in the form of file PDF. I use Windows 7
ask as many question you need.did you download ARC?
Yes I downloaded the software but believing that I missed the note of assembly and the instructions for use of the software I stopped. I possess several robots and every time there is or a CD or instructions for use and notes downloadable.
