Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Multiple Serial Devices On Ez-B
DJ, I see that you set both the new H-bridge and the MP3 trigger to Port D0 for the Serial communications. I already have the BV4113 Motor Controller, before I order the Sparkfun MP3 Trigger I would like to verify if I can connect one of them to an alternate port and configure it as a secong serial out port?
There is a drop down for the port selection (on devices that allow port selection) by pressing the Config button.
MP3 Trigger can be connected to any port. Use the drop down
BV4113 can only be connected to D0, you will not be able to change its port if you try
Excellent!, Thanks for the quick response. Merry Christmas and happy holidays!
