i just saw the first jd robot and i love it very much. are there more video of this first jd? love to see them.
congrats dj&team and thanks for so much fun
Sphero Movement Panel
— Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots.
This old forum post has the only footage of the prototypes: https://synthiam.com/Community/Questions/5612
That was all created in my basement many many years ago
It's crazy looking back and seeing where we are now!
yes indid.you all work so hard and with great sucses.you gave many, there dream robot&hobby.
Thanks @Nomad6R!
Has anyone built the JD robot much taller using the extension modules and would it still walk if it is much taller?
roborad
jd has hips that works perfect.i think if you want a bigger robot, you will need to use metal brackets.
Yes thanks Nomad,That is what I thought too but It would be a worth while project if the servos are strong enough.
you can always try,you never know what you come up with. i think the cube on elbows and knees,would be possible. then you just need to adjust some motions like sit down&stand up.
