Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Minimum Screen Resolution For ARC
What is the minimum recommended screen resolution for running the ARC application on a Windows PC? I am currently evaluating Single Board Computer (SBC) displays and need to know if there is a recommended user interface resolution for ARC. I've been unable to find this information within the ARC system requirements.
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
Ya, that info is kinda buried in the support section under Troubleshooting/Screen Resolution. You can find it here: https://synthiam.com/Support/troubleshooting/screen-resolution
It says:
Quote:
Screen Resolution The minimum screen resolution for ARC is 1024x768 at 100% scaling. Ideally, the recommended resolution for ARC is 1920x1080 or higher at 100% scaling. For 4k monitors, a scaling of 150% or 175% may be sufficient. Scaling will increase the size of fonts and buttons on the screen, leaving less space for additional robot skills.
Resolution Scaling Microsoft Windows has a feature to configure scale sizing, which will affect ARC's interface. If the scale sizing is set larger than recommended (100-125%), there will be less screen real-estate for robot skills, and scrollbars will be used. Restore the scaling size of Windows to the recommended sizing by following these steps...
There's more so maybe you should have a peek yourself. Have fun!
Hi smiller29,
The minimum screen resolution for running ARC is 1024x768 at 100% scaling. However, it is recommended to use 1920x1080 or higher at 100% scaling for an optimal experience.
A few additional points to note:
  • Scaling Adjustments:
    If you're using a 4k monitor, a scaling setting of 150% or 175% may work, but increasing the scaling beyond 100-125% can reduce the available screen real estate for robot skills. This can result in fewer skills being visible and the interface may start to use scrollbars.
  • Windows Scaling Settings:
    Ensure that your Windows scaling is set within the recommended range (100-125%) to prevent UI elements like fonts and buttons from expanding too much.
For further details, you can check the troubleshooting page on screen resolution here:
ARC Screen Resolution Troubleshooting
Do you need any more information or assistance with your LattePanda setup for ARC?
