Yeah - if the company chooses to lock down the SDK to paying enterprise customers, there's no easy way to control it. It's too bad, because if the SDK were available, it's simple to build a plugin and voila, a real robot!
I did have a look at it but it looks a fairly complex job to use it
Yes... all the samples are in Java and the Loomo OS is Android
You don't have to write a program that runs on Android - it must have a TCP Server or some sort of MQTT or messaging or protocol or something that allows remote control of it. If there is, then it's super easy to whip up a plugin. I just need to see the documentation on it.
Get me a protocol manual, or even the SDK if it's in java or what ever.. I can make a Movement Panel for ARC super easily.
link to API and SDK
Hi,
I included a document which is a copy and paste of the SDK overview. I have also included the link to the online documentation ( no downloadable PDF is available). To access it you need to logon (it is free).
It would be great if you could make a Movement Panel for Loomo.
Thanks,
Peter
Their SDK is not open. Unless they publish a communication protocol specification, there's nothing i can do. I reviewed their developer page and the Connectivity class is what we need to see. There's nothing I can do at the moment based on what little they have given developers. They have only given android library documentation for an SDK with no documentation on the protocol. They have a very closed system.
