Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Listen To Eventhandler In C++ Without Gui
I'm attempting write a small c++ cli program with which I can connect to and control each servo. However, I am running in to the problem of making the connection without using a gui. Does anyone have an idea of how I can listen to the eventhandler without using the gui?
What I have so far is this:
#include
#include
#include "stdafx.h"
using namespace std;
using namespace EZ_B;
using namespace System;
int main(){
	EZ_B::UCEZB_Connect^ ezB_Connect1;
	ezB_Connect1 = (gcnew EZ_B::UCEZB_Connect());
	ezB_Connect1->Name = L"ezB_Connect1";
	ezB_Connect1->Port = L"192.168.1.1:23";
	ezB_Connect1->TCPPassword = nullptr;
Any help will be highly appreciated:)
Best regards, Lars
Do not use UCEZB_Connect because it is a graphical user control (hence the UC in the naming convention).
Use EZ_B::EZB instead...
EZ_B::EZB will provide a Connect() method which you can call directly
    EZ_B::EZB ^ezb;
    ezb = gcnew EZ_B::EZB("MyEZB");
    ezb->Connect(L"192.168.1.1");
    for (int x = 0; x < 10; x++) {
      ezb->Servo->SetServoPosition(EZ_B::Servo::ServoPortEnum::D0, 40);
      System::Threading::Thread::Sleep(1000);
      ezb->Servo->SetServoPosition(EZ_B::Servo::ServoPortEnum::D0, 120);
