Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Linear Actuator
Im looking for a linear actuator that has 8-12 inches of travel. All the ones I am currently finding have through pin hole ends on both sides of the actuator. Does anyone make one with a square flange with four perimeter bolts on the motor end and just plain old threads at the end of the movable shaft. Tried googling also and couldn't find anything. Thanks Chris
ServoCity has lots of neat hardware for mounting to linear actuators. You may find something useable there. However, their linear actuators are fairly expensive and all seem to have the through hole mounting.
Can you provide us with a sketch of what you are looking for and your application?
mounting_brackets
pictures
