Hello Everyone,
I was wondering if anyone knows how to wire LEDs to the EZ-B?
What kind of LEDs are compatible as far as voltage and brightness and do I also need resistors?
Please let me know when you can.
Thank you,
Chris
Speech Recognition
— Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
Hello Everyone,
Thank you,
Chris
LEDs are simple to add. Using the digital pins outputs 5V when on, 0V when off. Leds can be rated for 2.5V to 3V so simply pick a current value suitable and calculate the resistance needed for 2V. [V=I*R]
Also, if you are powering the LED from the EZ-B signal line, you won't need a resistor. You only need a resistor on the EZ-B if you are powering the LED from the +5 and GND. But if it is the signal line (where you can control on or off) then you don't need a resistor
Thanks Guys!!!
I remember seeing a tutorial on this web site on how to add them to the EZ-B.
If you know what I am talking about, please send me the link.
So if I am correct, you connect the ground to the ground and the psitive to the signal?
Thanks,
Chris
GND-Cathode (-) Signal-Anode (+)
Yes exactly as you have it.
Sweeeeettt!!!! Thanks!
Can I connect these in a series to one digital port or do i need to connect one LED to each digital port?
i really just want to connect two for the eyes and here are the LEDs i am planning on using:
10 mm Ultra Bright LED FW Supply: 3.5V (typical), 4V (Max) FW Current: 20mA
Let me know what you think of this LED, or if you can suggest other ones that i can use.
Thanks again for the help.
Connect in parallel you can probably place 10 perhaps. I use a 7.4V 910mAh LiPo which gives me roughly 220mA on a port, I think. Those will work fine.
Sounds good. I am only going to have two LEDs for now so I think I should be fine.
You have been a great help, and I really appreciate it.
I will let you now how it all works out.
Thanks again.
Hey orwnic82,
I heard that it is not good to wire LEDs in parallel. What do you think?
