TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Resolved Resolved by Danger!!
Just Got A Jazzy Pride Wheelchair-need Help With Wiring.
Just Got A Jazzy Pride Wheelchair-Need Help With Wiring.
Well, Just got a Jazzy Pride wheelchair. It has three wires going to a plug that is for the power and on/off switch.
I also have a din jack that goes to the joystick. There is also a potentiometer in the circuit to control the speed.
I have seen where I can hook the motors up and run them full blast, but is there a way to hook up to the joystick that is in the wheelchair and cut the wires going to the pins of the joystick and hook them to the EZB?
Will I require a Saber-tooth H-Bridge?
Will i also require a 25A regulator?
I have zero left in my budget.
thanks, Mel
You actually Heard my question. I have a communication problem in my brain and sometimes people do not hear what I am saying. It is not their fault, it is mine.
Dumb question: How do you remove the electronic brake? I have been scouring the internet but have found no "instructions" for that. I am reluctant to pull my motors apart without knowing what I am looking for.
@Brett
There are several videos out there, but this one shows it pretty well.
This made it so easy! Thanks! What sabertooth controller do I need to use with my 24V motors?
#15
@bret.tallent It is the amps, not the volts you need to worry about for the motors. Most people find a Sabertooth 2x25 to be correct. Some use the 2x60 but from what I have seen in Wheelchair motors, that is overkill. Most draw 20amps.
