These look amazing. Great project for Halloween or a cyborg.
Troy
— Edited
3 Participants
Python Native
— Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control.
Love the effect. How would you control the Teensy via the EZB v4
The teensy could be controlled with serial commands thru a UART. It has several uarts that could be used. Just need to hook one of the EZ-B UART TX lines to one of the RX lines on the Teensy and connect a ground line between the Teensy and EZ-B and the rest is programming. I did something similar a while back with two Microviews. I would send the Microviews an L for look left, an R for look Right, a U for look up, etc. It worked quite well. you would need to modify the teensy code to set up the serial link and process the serial commands. The EZ-B code is simpler since it is just a matter of sending the commands.
Great find. I have a project for this.
@ fxrtst Is it a Halloween project?
No, it's not, but that's a good idea too!
