Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Is There A Quick Hack To A Rad 2.0?
I just found a rad 2.0 i want to hack just want to know if it is a few wire hack or a full on for the basic system ? I have not been in there yet ( stupid job lol. taking too much of my robot time)
As far as I have seen you will need to gut it and spend some time fitting in the new parts.
One thing I remember reading was that all wires are soldered rather than on plugs which means disassembly requires cutting wires (or de-soldering them). That in mind I would say that it's not going to be a quick & easy hack.
Josh likes his RAD robots and has done a few of them, check the showcase for his work it probably gives a lot of details.
CHECK MY POSTS i have over 6 RADS and using them for different projects
Also another project in showcase is (its going to be RAD) by another member
PLUS BRET TALLENT has some RAD projects also
BUT i think best info on one is going to be rad project
