Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Hi Jaychadw, At first I was thinking the same thing but an accelerometer is a type of inertial sensor. Apparently there are inertial gyroscope sensors as well. Here is a link that talks about the two. So you can get an Inertial Motion Unit (IMU) that has both in the same card.
Thanks Troy. I've been reading through a number of different things and they are referred to as seemingly different things, yet read as being the same. confused
I'll have a read through that and see if it clears anything up
Hi Jay , what are you needing /using it for. If we know your idea for use we can be more helpful.
I was wanting it to know the precise(ish) motion of the robot. I already have an accelerometer and that works ok. Although it seems to crash when it goes upside down.
I know that can be used to measure movement I just wanted to know if these were anything different of simply another name for it
